Quick newber question on the different differentals
Koenigturbo
1,336
Oxnard CA
Which Models get the 3.75, and 4.30 diff'sand which ones get the L.S.D's.??, I'm guessing the turbo's model get's the 3.75. L.S.D.'s
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
SEARCH.
Hell a Google Search, and the EPC will give you this answer.
To Narrow it down; Turbo from 87-Mid 89 has the 3.90, and the 1JZ had a 4.10 Torsen. You fill in the blanks. ;)
Koenigturbo
1,336
Oxnard CA
Zumtizzle;1401105 said:
SEARCH.
Why "Google when I can have smart guys like you to help me:rofl:
I'm a "Newbie::.........E.P.C????:3d_frown:
THANKS!!!!."Z"
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
Let me answer that question for you.
USA/Canada Destination:
86.5 - 92 N/A = 4.30:1 (USA: LSD Optional, Canada: LSD Standard) (Open Axle Code: G284 for Pre-89, G282 for 89+; LSD Axle Code: G285)
87-88 Turbo = 3.91:1 LSD Standard (Axle Code G315)
89-92 Turbo = 3.73:1 LSD Standard (Axle Code G305)
Japan JZA70:
1JZ-GTE Automatic = 3.91:1 (Torsen LSD Optional) (Open Axle Code: G314; LSD Axle Code: G319)
1JZ-GTE Manual = 4.10:1 (Torsen LSD Optional) (Open Axle Code: G294; LSD Axle Code: G299)
Jeff
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
SEARCH.
Not quite. Should have left your post to just the first bit, maybe then he could have searched and found accurate information, lol.
Jeff
Turbo Habanero
4,229
Tucson,AZ
Hey i mean thats what this forum's about helping and learning correct. Sure he could prob found it through google But what does it matter. Helped me out to thanks Jeff
One question whats better 3.91 or 3.73 and why?
Koenigturbo
1,336
Oxnard CA
Japan JZA70:
Jeff
Thank you Jeff!!
Your the parts wizard, that's for sure!!
PureDrifter
VIP Cruisin'...
Aug 11, 2009
317
CA
www.clublexus.com
slightly nub question, but aside from the LSD sticker, how would one identify a junkyard diff for ratio and LSD? assuming of course it isn't in a car (which makes it easy)
Drake69
Enjoyin' mah ride...
Aug 24, 2009
648
Richmond, Virginia, United States
Interesting. Then, according to this, limited slip comes standard on all models after 86.5. If that's the case, then what is MVP Motorsports selling in their TRD LSD Upgrade?
TRD LSD Upgrade for 1986-92 Supra Turbo & Non-Turbo
Part # TR 41301-JX000 MK3
This Limited Slip Differential (LSD) upgrade will assure that you deliver equal power to both rear wheels, giving you more responsive and safer handling abilities.
NOTE: Fits both Automatic and Manual transmissions, all years.
MSRP $1,078.43
Your Price $943.00
PureDrifter
VIP Cruisin'...
Aug 11, 2009
317
CA
www.clublexus.com
because the factory LSD is nothing compared to a properly functioning clutch type LSD. aftermarket and TRD are generally a LOT more aggressive than the OEM one.
lol, thanks for the counting teeth tip but i was hoping to avoid having to crack diffs open at the junkyard :p
mdr40z
arkansas
qualify better.
3.73 will get a marginally faster top end, 3.91 will be marginally quicker
3.73 is marginally better gas mileage
Turbo Habanero
4,229
Tucson,AZ
mdr40z;1402118 said:
qualify better.
So higher the ratio the better accel you get? The lower the better top end/gas mileage you get?
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
--Wolf--;1401766 said:
What diff does the JDM 86.5 (factory 7mgte) have? (digital dash model)
For JDM MA70's (Pre-89):
Automatic: 3.91:1 (LSD Optional)
Manual: 3.73:1 (LSD Standard)
No, LSD was standard on turbo models and Canadian N/A models. It was optional on the N/A in the USA for 86.5 all the way to 92.
The factory MA70 LSD is a clutch type LSD :aigo:
But you are correct the TRD and other aftermarket LSD's will be more aggressive than the factory LSD, but you will sacrifice some driveability in the name of a better performing LSD. (Noise while turning at low speeds, possibly small amount of wheel skip).
TRD/Aftermarket are typically stronger than the stock LSD, especially the Torsen LSD used in the JZA70.
Jeff
Turbo Habanero
4,229
Tucson,AZ
Jeff
Is the torsen not as good??? i was under the impression it was better?
