quick ? for single guys
boostindoo
179
raleigh
where are u running ur vacuum line from the wastegate? i think its supposed to go to a nipple on my turbo but i dont have one, so we ran it to the manifold. im having boosting issues and was wondering if that would affect it.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i would get a nipple and tap the comp housing. thats what i'm going to do as mine has no nipple on the turbo either.
it will definitely be laggier
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
My Wastegate runs off my manifold, but I'm going to tap the compressor housing and put it on there. Running it off the manifold won't create a laggier spool, it only means that the signal going to the wastegate is lagged. This means that you CAN have spiking or oscillation issues with your boost pressure. However, with such a large turbo like yours, it won't really matter that much. It will probably work fine. If you DO have spiking issues, then move it. Some cars run this way stock (like old Volvo Turbos) They had mad spike issues because of it, but they ran a pretty small T3.
As for the ISCV, I just left mine open (Actually, I stuck a cork in it with a small hole drilled in it, as my ISCV doesn't work)
boostindoo
179
raleigh
cool, i like that tap that goes to the coupling instead of the compressor. thanks hottscennessy! if u guys seen my dyno sheet, the boost is going nuts! looks like a mountain range.
OneJoeZee
Retired Post Whore
aboard the Argama
What about the ground that attaches to the stock twin intake pipe? The one that's held down by a screw that also holds down the RHD throttle body clip.
