is this procedure recommended on new cars too??
RPSil13 New Member Nov 30, 2006 464 0 0 Anaheim, CA Sep 23, 2010 #21 is this procedure recommended on new cars too??
Poodles I play with fire Jul 22, 2006 16,757 0 0 43 Fort Worth, TX Sep 23, 2010 #22 NashMan;1620388 said: nope you do not stock diff drive around for like 500 drive as your Normy do drain oil done no stuiped high speeds thou after maket lsd metal type such as kazzz lot's of figure 8's forlike 1 half an hour then drain oil Click to expand... No, there's more to it than that: http://www.marlincrawler.com/tech/differential-break-and-care-information RPSil13;1620403 said: is this procedure recommended on new cars too?? Click to expand... No, new cars are already broken in for the most part. Just don't abuse them. Motorcycles on the other hand have to be broken in.
northwestsupra New Member Sep 19, 2006 1,166 0 0 Washington, Marysville Sep 23, 2010 #23 Well all I ended up doing was put in all new bearings and seals and a new crush sleeve. So is there going to be anything I should watching back there? Sent from my Droid using Tapatalk
Poodles I play with fire Jul 22, 2006 16,757 0 0 43 Fort Worth, TX Sep 24, 2010 #24 Shouldn't need anything as long as it was setup right. Should have used a solid spacer in the place of the crush sleeve though...
