So I just turned the key last night and fired the Supra for the first time on my 7mgte stock rebuild. No major issues on start-up... I think I have successfully turned money into noise! I primed it to get oil pressure, started it up, and then let it run for a minute to make sure I wasn't leaking/burning/destroying anything, then shut her down.
I've done the reading up on jdub's recommended break in procedure of 3/4 throttle pulls followed by high vacuum deceleration in gear to get the rings seated, and it all seems to make sense to me: http://www.supramania.com/forums/showthread.php?t=48993
What I don't know is how critical it is to get those pulls done in the first X amount of time... I still have a vacuum leak around my injector seals, so I know I need to fix that before I can drive it. It should (I hope I didn't just curse it) be as simple as wiggling the injectors until they seal. But should I worry about getting it timed now, or is "timed well enough to run" OK for the break-in? What about burping the coolant system of air?
Fixing the timing, if I do it with the motor running, will inevitably get everything up to ops temperature, even with the little time it will take because it's warm outside. And it pretty much has to get up to ops temperature to burp the coolant. So I will basically be running at idle for ~10 min if I do these things. Will I be defeating the purpose of of the "hard and fast" break-in procedure jdub describes by letting it sit and idle while I tune things in? Any recommendations?
Thanks for any advice...
Dan
Oops... Just saw I clicked this into the "GE Technical" section... Can a Mod please move to the "GTE Technical" or wherever appropriate? Sorry.
Dan
