question: what is the difference in the supra and cressida 7mge?
jenny89
96
andersonville tn
i apologize if this has already been discussed but i couldnt find it if it has. So apparently the cressidas 7mge only has 190hp compared to the supras 200hp. Does anyone know what the difference is? The only differences i know of are the throttle body and upper intake. Could this b the reason?
They run a GTE style intake (3000 pipe is plastic) on the cressida. Outside of that, I don't see anything else different (cams are the same, etc.)
jenny89
96
andersonville tn
awesome thanks guys. the one i got was in pretty good shape but im rebuilding it anyway and using my old intake. whats the difference in the oil pan?
bioskyline
1,236
powell river bc
the supra nad the cressida use a diff crossmember, so the big bump in the oilpan and the oil pump pickup is different. easy enough to swap over. if you have the 2 side by side, it will stick out like a sore thumb
8,898
Cam on the 86.5-88 is different. The intake changed over to match the Cressida when it went 7M. As such, cylinder pressure is different with the compression test specs.
jenny89
96
andersonville tn
I got mine out of a 91 cressida so it should b the same as my 89 tho right? the cam i mean. I've got my old intake to go on it.
so they didn't put the 7m in the cressida til 89?
