SupraDerk said:^Just an exploding engine, haha ::w00t::
I lol'd
keep an eye on AFRs fa sho.
Thanks for the info. If I can't find any RX-7 coolers, are there any aftermarket ones that are up to par for a good price? Also, I noticed you went NA-T before, what is/was your setup?cjsupra90 said:yes the GTE electronics are better, but it can be done reliably as he is doing it as long as the tuning is spot on.
Oil cooler is a good thing, but dont was your time with the stock toyota setup, it is usuless by design. The stock cooler is to small to be an inline unit and by-passing a small amount really does no a thing for cooling and yes I have checked this myself using digital temp monitoring equipment (fluke meter with a special K-type thermalcouple) the best that we saw with the stock type cooling was only about 5* F not worth the hasle. If you want an oil cooler, use an actual inline unit. The best ones that I have ever used on any car and especially for the price that you can pic them up for is the stock units on the 86-92 Mazda RX-7's. They are very effiecent (and have to be do to the fact that 1/3 of a rotary cooling is done by oil where as on a normal piston engine, that number is about 1/6 or so) and another nice thing that is built in is a thermostat.
GotToyota? said:Thanks for the info. If I can't find any RX-7 coolers, are there any aftermarket ones that are up to par for a good price? Also, I noticed you went NA-T before, what is/was your setup?
-Matt
SupraDerk said:Seeing as how you have a Lexus AFM and a Turbo ECU I'm guessing you're going full NA-T?? In which case you will need to use the turbo wiring harness...and your parts list will need to grow quite a bit :naughty:
