I'll be going NA-T soon, and I'm making the list of parts I need. I was wondering if the stock accordian hose is the right size to clamp on to the stock N/A AFM, or if I will need to get a custom pipe made.
-Matt
-Matt
I dont believe the oil cooler is need eitherSupraDerk said:Intake manifold isn't neccessary
440 Injectors or better, SAFC, intercooler and piping, oil cooler, turbo, turbo manifold, turbo elbow, downpipe, BOV, better HG (cometic or metal or stock turbo), boost gauge, turbo FPR
That's pretty much it IIRC
Fuzz420 said:I dont believe the oil cooler is need either
Not true, my bud lasted 3+ years on that setup, and he just built another car exactly like it.s383mmber1 said:Matt, you won't last long on NA electronics.
Save up, and spend the money on GTE electronics.
Its only like another 300 or so dollars, and will SAVE you in the long run.
GotToyota? said:Not true, my bud lasted 3+ years on that setup, and he just built another car exactly like it.
-Matt
GotToyota? said:The GTE electronics are safer, but with fuel tuning it shouldn't be a problem. Also, when I get into the higher boost levels I don't have to deal with FC.
-Matt
