Question on OEM springs
bsupra
140
California
adampecush;1305565 said:
I suggest you do some in-depth reading and understand what fatigue actually is. It is not the degradation of the mechanical properties of a material. It is the initiation and propagation of cracking due to the application of cyclic stress. In the case of steel, this stress has to be greater than a threshold stress (aka the fatigue limit), otherwise, cracking will not occur. Guess what, vehicle bodies are designed with this fact in mind.
If your vehicle body has been weakened by fatigue to the point that it is noticable, catastrophic failure is iminent. I have yet to see fatigue cracking destroy the body of a supra, but hey, never say never. The rear subframe is a different story.
Better yet, ask a metallurgist (ahem). When you bend your paper clip, you strain harden it, reducing its ductility. Continued bending reduces its ductililty to the point where it can no longer bend and remain intact, so it breaks. Some call this low cycle fatigue, but it is not.
Apparently you do.
no thanks.
Ok I have my hands up already. I know I am out numbered. Here is the last thing I have to say. I know body cars are designed for that but constant bending and flexing of abusing your car without proper support it will still weaken. ANY THING THATS IS ABUSED WEAKENS SPECIALLY WHEN CONSIDERING THE AGE OF THE MATERIAL. I could not say anything anymore your a metallurgical engineer. Im just a mechanical engineer getting my masters. Thats ur major so I could not argue with that. Me, as a manufacturing engineer, I still respect the wokrer ideas and comments because they are the one that sees the problems that engineers does not expect to see.
ok thats it for me
dbsupra90
toonar
indiucky
dbsupra90;1304219 said:
i didnt know whiteline made springs for our car. i looked it up and couldnt find it on their website. i found the p/n (from 2004) and searched the distributors and was not found.
do they no longer make them or is there a new p/n for them?
i think this got lost in the mayhem.
any ideas?
5
Whiteline springs are discontinued, you'd have to find em secondhand.
Hell, they used to make coilovers as well (not sure if they did for our cars), and they actually were valved for the vehicle...
Satan
Tampa
I've got a set of springs that you can have for just shipping... Came off of my 91 Sup... Will have to get ya mileage info if they are tems or not (not sure if there's a difference).
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
ok thats it for me
Your a masters ME student and are not familiar with metallurgy past some Wikipedia articles??:3d_frown:
If designed properly, a piece of steal can go through infinite load cycles without failure. Assuming Toyota knows what they are doing, which they do, and the safety factors involved there should be no issue with the amount of loading the chassis sees with the top off and actual yielding/stress fracture of the unit body.
If using other materials such as aluminum this is not true and at some point the material will fail no matter what the loading is (think air plane wings which is why aluminum wings are constantly inspected and have a set shelf life for the cyclical loadings they see). The higher the load applied the less cycles until failure.
bsupra
140
California
to the moderators Im just going answer his comments with no harsh words and i will be calm.
I guess this will never end. :icon_bigg First of all I know about wikipedia is a bad source. I could not give out my password from my online library at school. thats why i looked at what I can find online. Second, Im not a masters student yet, im trying to.
You said above "if designed right". As an engineer your self, you should know that not every design is perfect. for example; blown head gasket, cracked rear subframe. There will always gonna be flaws on every design. Thats why engineers learns from that mistake and make improvements like the 2jz. And as a production made cars, its like any other production. I do not know about cars but they put car to the test before they start building it. Now, through production line, you can not test every single car that comes out of the line. From building of parts to assembly there will be some flaws. Thats why production cars look the same but inside they are not 100% all the same the way they were made. All Im just trying to say, probably the supra I got probably got one of those flaws.
I may not be a design engineer, but as my past experience of being a manufacturing engineer. I saw things that I never thought could happend. Thats why I take inputs from technicians that see those things every single day, put those inputs together to make a better design.
As for the age of material that im talking about. I am not talking about old age it gets brittle, No. When I said age of metal, meaning the age of technology it was made. Better technology, better process of making this things.
to the moderators, I just defending my self from getting insulted. i never said any harsh words this time. I know you guys are way smarter engineers than I am. The way I look at things is probably just different from you guys point of view. I am more of a practical type of person when it comes to this kind of things, I just consider things thats out there and be ready for unexpected.
Ok. so please I never meant to harm anybody. So please stop insulting me for being an engineer. I know I am dumb engineer to you guys but there are still some people out there that appreciates it. I think I already said everything that I have to say. ok :icon_bigg
