IJ.;1478174 said:
I remember that
About right for the "gunna" Mk3 community though.....
as in "I'm gunna do this and I'm gunna do that" and it never actually happens..
yea it was quite a while ago. I wish i had looked at in more detail. for some reason though i dont think it was a true sequential. ill try to see if I can dig up some details on it.
regardless all im saying is they do exist, they wont be cheap and IMHO are not needed. you can always dog the gears in the r154 and no lift shift it in the standard H pattern
http://www.mkiiitech.com/forum/showthread.php?t=308
^^^^^^^^^^EDIT im awesome
alright another edit
after further research I have remembered what I originally was thinking about. It does not do true up and down sequential shifting it is described here.
"QUOTE]It locks the first 4 gears into a sequence that cannot be screwed up basically. Its designed for drag racing only, its not really any use for anything else.
So you select first, lock the collar into position. When you want to change to second you wack it straight back, push straight up to get third and straight back to get forth.
Its a good bit of kit!
Gaz."QUOTE]
