Hi Guys,
I have a question, you can maybe answer m. A friend of mine who also has a 91 MKIII 7MGTE has too high oil consumption. His engine needs about 3 or 4 liters per 1000km. He already changed the turbo more than once, and that doesn't seem to be the problem. He also removed the spak plugs, and the all have a healthy color. He also had the compression checked, and it seems to be fine. Because he couldn't figure out what the problem is, he deregistered his car, and took it of the road, and now wants to safe up to rebuild the engine, but i don't think it is realy necessary, because the eingine otherwise it not in bad condition, not too many km, and never seen more than stock pressure. The headgasket was replaced already and so where the valve seals. We wondered what else it could be. He believes the oilrings of the pistons are damaged, but if it were so, then the spark plugs would not have the normal healthy color, but would be black from burning the oil. What other possibles causes are there?
Thanks a lot guys
Mark
Thanks a lot guys
Mark
