Well, my IS300 OD swap just became reality.
I just wish I had kept the IS trans, instead of sending it to the scrap yard.
I had checked when I pulled the OD assembly out of the IS trans, that the A340e OD slid in with no issues,
and the higher flow IS pump assembly was dimensionally the same.
Never thought about the IS OD assy being larger in diameter.............
It hit the overdrive brake piston, OD brake spring assy, and the OD support.
All of them, plus the OD planetary ring gear needed machine work to fit together.
I am sure that if I had keept those pieces from the IS tranny, the job would have been much easier.......
Or better yet, if I could have just found an A340e from Japan, that had the .75 OD ratio in the first place
But it is in now, and just waiting for a fresh filter to show up (and to get the engine put back together),
and it will be ready for a test.
