Question about fuel injectors
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Yep. The stock regulator is NOT adjustable. You have to drill out the orifice in the J-tube with a higher flowing pump or you will have high fuel pressure and probably run very rich. An adjustable fuel pressure regulator will bypass the J-tube.
Koenigturbo;1560982 said:
Whtma71, that's good answer. what's the cut off point for as far as boost on this set up? Can you go 18ish?
It all depends on your other mods. Turbo size, exhaust,and larger intercooler piping plays a big role. You might be able to run 15 psi on a stock turbo(not that you'd want to) with stock IC piping/exhaust but once you upgrade those you could only be able to run 12 psi.
Will larger injectors and a piggyback you can usually run a little more boost depending on how much fuel you have to pull.
Koenigturbo
1,337
Oxnard CA
WHTMA71, here's my mods: threee inch turbo back exhaust, 57 Trim wheel, 550's, Lexus, boost controller, A.F.P.R., Walbro. M.H.G.
borisupra
26
Bayamon
Nick M;1561475 said:
New is also good.
http://www.suprasport.com/LIPP-AFM-with-adjustable-set-screw_p_178.html
Here is an example compared to stock.
very interesting site but it says that they are out of stock and that was on june 09 lol but i like the
http://www.supramania.com/forums/sh...ser-3650-lb-sled-thread&highlight=sled+thread
------very interesting site but it says that they are out of stock and that was on june 09, i like koenigturbo mods i dont want to built a 1000 whp monster lol i like that afm in suprasport.
