The way I see it is.. If your lights dim when the bass hits.. Then the voltage in the whole car is dropping. So what's the difference if you run a fuel pump off the amp wiring, or run a dedicated supply to the pump? Either way when the bass hits the voltage is going to drop. Get a better battery (that is, if the lights do dim...), and a distribution block and do it.
