PTE 780cc Injectors, anyone using these?
empera
Authorized Vendor
Philly.
i wanna know how well they fit you rail/head or have any issues using them. i just bought a set and want to know if i'm ok with them. model number 17113742
and they look like this.
quake
toyota tech
Apr 13, 2005
619
r.i.
im using the 1000cc precision injectors they are delphi injectors, just call t hem and make sure they fit the eclipse turbo. Also make sure you have the correct impedence for the ecu you are using
Adjuster
I think these are the same ones I have.
780cc Delphi injectors, the body is turned on a lathe to fit our fuel rail/head design.
They are low inpedance, and the TCCS fires them fine.
Idle is fine.
I'm pulling 42% off the mainscale to make them work. (So if you do not have a way to adjust timing, it's not likely a good idea, but the car runs.)
I have the MaftPro, but have not adjusted the timing.
My car is for sale BTW. (It includes the 780cc injectors if you want a set.. LOL)
empera
Authorized Vendor
Philly.
yea i just noticed they dont really sit on my head too well, i found some o-rings that might make it work tho, just gonna hafta wait and see...
williamb82
909
4
Tampa, Fl.
i have some pte 780's installed. had to flip the fuel rail spacers around as they are a lil longer but fit fine and work great. also, when installing, the insulator at the head had to be installed into the head, and then the injector int othe insulator (the big rubber ring). was a lil tricky getting the rail on all the injectors since they had to go in the head first but i love them so far. mine were fresh rebuilt and balanced when i got mine. running 20psi with my 57 trim ct26. no issues.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
isnt pulling that much off the mainscale going to affect your timing?
your selling your car!!! i hope your planning on getting a new one
