ProSport gauges? (Iuno what section to put it in)
Fubar231
402
columbus
gaboonviper85
3,236
Northeast Philly
All the electronic guages have an opening sequence where the needle does a full sweep...
Prem guages have peak hold and warning....so after a hard run you can see what your max boost, max water temp, max whatever....only the premium guages do this...the warning you can set the guage to alarm out and flash if you go over a pre set level "nice feature in oil and boost guages"...
I'll be going with the premiums myself:)
Fubar231
402
columbus
LilMissMkIII;1505759 said:
The only con of them is the super loud beep on the initial sweep.
Other than that, I can't fault them :)
What gauges do you have?
Im about to get the premium oil psi and water temp ones, but i don't know what adapters i need etc. I made a post in another thread about how to hook up an aftermarket oil psi gauge, and someone said i need a Y splitter to run it off the stock sensor location, and some other people say they jsut removed there stock sensor completely.
Im trying to figure out how people have there oil psi / water temp gauges hooked up.
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
I have the metric water temp + boost guage + A/F.
Looking to get an oil pressure one also.
(I run a digi dash, and am not sure it's 100% accurate, so trying to replace all my stock guages, and then some)
Fubar231
402
columbus
So this is what im about to order, does this look like everything i need to install the gauges too?
(Water temp gauge radiator hose adapter piece)
http://prosportgauges.com/water-temp-sender-radiator-hose-adaptor.aspx?variation=18
got the 34mm one for the supras
(Adapters for stock oil sensor location, from 1/8 bpst to 1/8 npt)
http://prosportgauges.com/metric-adaptor-kit.aspx
and then the oil psi and water temp gauges
http://prosportgauges.com/amber-white-premium-oil-pressure-gauge.aspx?variation=136
http://prosportgauges.com/amber-white-premium-water-temperature.aspx?variation=138
So does that look like everything i need to get in order to install the gauges?
I6Boost
182
My Supra
Yes i have the EGT and Boost gauge, i love these gauges and all my buddys run them.
Style is great and they look bad ass.
