IJ. said:
The local wave generator I was talking about is an adaption of the Islay and kicks it's arse with some insane internal mach numbers for the air flow.
I missed that yesterday, sorry.. Did they explain how they kept the generator spinning in the same direction even though the air is moving in opposite directions?
I can't seem to figure that part out yet?
Edit: Is this the company you speak of?
http://www.energetech.com.au/
Ohhh, they change the blade angles I think.... coool....
Most turbines are designed to function for gas or liquid flowing in one direction and at constant velocity with the blades designed to take advantage of the optimal ?angle of attack?. However, when the flow is not always from the same direction or a constant velocity, traditional turbines become ineffective.
Previous attempts to address this difficulty have mostly resulted in turbines with varying degrees of efficiency. The Energetech turbine, however, uses a different method, which with its slower rotational speed with higher torque improves efficiency and reliability and reduces the need for maintenance.
The turbine uses a sensor system with a pressure transducer which measures the pressure exerted on the ocean floor by each wave as it approaches the capture chamber, or as it enters the chamber. The transducer sends a voltage signal proportional to the pressure which identifies the height, duration and shape of each wave. The system will be calibrated to small-scale ?noise? from activating it.
The signal from the transducer is sent to a Programmable Logic Controller (PLC) which adjusts various parameters which will be selected based on particular conditions and energy content of each site.
