Hi All,
I have a pretty interesting scenario as my car had fully functioning PPS (albeit it sometimes felt a little vague, but was none the less power steering) until my last oil+filter change which I did three days ago.
I accidentally did the mistake of leaving the reds on for about 30 minutes and then after I lowered the car from its side I then proceeded to reverse her out and steering felt dead. Not as dead as the car turned off but boy was it a workout.
Did some research on here searching old threads and have since performed the reservoir maintenance and it was full of gunk the mesh was completely black and it was amazing anything ever worked based on that.
I have since cleaned the reservoir mesh and replaced the fluid in the power steering system but I still now have no power steering. I have also read on a thread that Ian mentions the speed sensor?
Can anyone give me any idea's as to what may be going on here?
Did I burn the pps ecu by leaving the reds on?
Any help is greatly appreciated.
Also if it's the pps ecu that needs to be checked, where would I find it?
Many thanks guys!
Many thanks guys!
