The problem that he is having is an issue on some cars. Like I said in my last post, I think that toyota had changed the casting at somepoint and made the housing that the bucket rides in thicker. I have installed several sets of studs in different 7M's and some fit and some dont. Adjuster, I have tried the method that you stated and and it didn't work. With the stud installed and the head sitting on all the way down, the nut will not go on the stud as outside of the bucket housings interfer with it just as he said was his problem. Now that I think about it, the casting was probably not changed, but the tooling diameter was changed that was used to create the machined releaf in the housing and there for offers less clearance.
For anyone that does not beleave me, you are more then welcome to come and try it on my head when my motor comes out to put my 1UZ in.
