I just finished bolting the 1jz in to car and wanted to prime the oiling system before I went too much further. Is there any way to do this? I cranked the car for several 6-8 second bursts about 12 times and didnt pull oil to the hole where the stock switch is located... I did have a little drizzle from the rear port where the twins feed. I didnt want to crank it too much without checking with you guys first. Let me know what you think. How long should I expect to crank it before i build pressure?
thanks
--James
thanks
--James
