So my build is almost done. Its taken most of the summer cause of stupid delays and hang ups. My third supra was NA and im doing a full NA to Turbo swap. The motor is almost assembled just waiting on a few gaskets from toyota to put the stupid bullshit on. The Head was rebuilt by Toyota, and the block was completely rebuilt by a local machine shop. I put JE pistons with JE rings, Eagle rods, and Clevite bearing in it. New oil/water pumps from toyota. Titan 1.5mm mgh, sadly a stock ct-26, turboxcess boost controller, autometer boost gauge, non turbo trans, na rear end with the 4.30 gearing. stock intercooler, Apexi SAFC, Walburo fuel pump, ARP head studs, Chinese downpipe(pretty gay but i needed one for now and it was cheap), running straight out the downpipe. Stock turbop ecu. Can't think of anymore at the moment. Will have pics up soon. Im planning on running 11psi untill i get a VPC. hopefully ill make decent power. My last turbo 7m had an hks exhuast and shims on the wastegate so i wasnt makin much in the way of power. Hopefully ill make more on the go around. All input would be much apperciated. Im hope to make some decent numbers.
