pretty stoked
NeoJester
104
Emo
So my build is almost done. Its taken most of the summer cause of stupid delays and hang ups. My third supra was NA and im doing a full NA to Turbo swap. The motor is almost assembled just waiting on a few gaskets from toyota to put the stupid bullshit on. The Head was rebuilt by Toyota, and the block was completely rebuilt by a local machine shop. I put JE pistons with JE rings, Eagle rods, and Clevite bearing in it. New oil/water pumps from toyota. Titan 1.5mm mgh, sadly a stock ct-26, turboxcess boost controller, autometer boost gauge, non turbo trans, na rear end with the 4.30 gearing. stock intercooler, Apexi SAFC, Walburo fuel pump, ARP head studs, Chinese downpipe(pretty gay but i needed one for now and it was cheap), running straight out the downpipe. Stock turbop ecu. Can't think of anymore at the moment. Will have pics up soon. Im planning on running 11psi untill i get a VPC. hopefully ill make decent power. My last turbo 7m had an hks exhuast and shims on the wastegate so i wasnt makin much in the way of power. Hopefully ill make more on the go around. All input would be much apperciated. Im hope to make some decent numbers.
koulee
497
While the block is still out, you might want to shim the pump for more oil pressure as extra insurance against RK. Thats about all I can come up with at 3am!
Syris
Need Rust Repair
Aug 24, 2005
687
Bryan, OH /Lima, OH
Hey nice to see another supra owner close to the area. My supra is lil west of you about an hour, whereabouts of toledo are you?
NeoJester
104
Emo
i actauly live in sylvania but no one knows were thats at so i put toledo. sylvania is basically conjioned to toledo
I agree with FT, as usual. The R-154 is so much stronger. I don't know how much the W-58's are suppose to handle, but I would definately be on the lookout for the 154 if I was you. Good luck getting it all together.............lol
NeoJester
104
Emo
i was wondering if with this build up if id be able to put 300+ like 312 to the wheels with boosting at like 11-12 lbs i know its a lofty goal but wonering if its possible
