Pressure plate bolt question
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
Bethpage, New York, United States
2JZ-1JZflywheel-Spec 7MGTEclutch/pp-1JZBH-R154 blah blah useless info
I cant seem to find out which bolts to use for the Pressure plate to flywheel I allready have the ARP's for the flywheel-motor. I would asume 2J bolts? and there are only 6 right? Any place to get them cheaper then my local dealership?
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
Jeff watson at champion toyota should be able to get you a better price. And as far as I know, you need to use the 2j ones.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
everything clutch on is 7M stuff. i used toyotapartscheap.com a lot too but either way they will be base price
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
I bought the MK3 bolts and they weren't long enough to go through the Spec pressure plate. I then got MK4 bolts and they "to me" looked identicle in length. I emailed Driftmotion about them and they said they had them for sale on the site but they dont and they havent gotten back to me. Im pretty pissed I wanted to get the tranny attached to the motor during the weekend but no such luck
mobes
Supras are never 'done'
Bozeman, MT
I show 90119-08302 for the JZA70, while the MA70 is 90119-08322. Not sure why the difference, maybe the JZA70 ones are in fact longer. I would think they'd be the same. Is the SPEC pressure plate really that thick?
Take a bolt to your local bolt specialist and say "I want some like this but x-mm longer please and Grade 8 or better.
Probably cost $10 and you're set for the trans install.
The PP bolts are as highly stressed as you'd think but still need to be decent quality.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Errr... it's a well documented fact that the SPEC pressure plate (at least for stage 1, 2, or 3) *is* a Toyota PP that's been painted blue. Hell, it still says Toyota on the casting!
Is the pressure plate properly aligned and on the dowel pins?
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
I beleive you I'm sure the 7M's would work fine Its got to be Toyota they wont admit when they are in the wrong and once I take things out of the bag I cant return them.
It wouldnt be the 1st or 10th time this dealership has messed my Sh*t up
It does have toyota in the casting so Im sure its the right one.
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
Ill have to use your numbers and order them from a different dealership
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
The only ones Ive found so far are too long and are like grade 5's
Ill Keep looking for a fastener place around my area....LI sucks
tissimo
Stock is boring :(
Melbourne, FL
those are not the right bolts.
Ace hardware has a metric section. At least all of em if FL do. Did you ask one of the people that work there?
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
Thanks for the numbers guys Ill see if i can get the retards to order the right Sh*t this time
I spoke with a parts guy just now and he said what is listed in their computer is 90119-08026 so I told him I wanted 6 of the
08322's
