Preferred clutch brand?
VanSupra
Van,B.C.
X-man
member
Dec 5, 2005
309
Pulaski,Va
I installed a ACT PP/ HPF bronze disc in a 91 I built and it is a very streetable combination. The ACT plate is a nicer daily driver plate but will still hold some serious power. The car I'm speaking of is tuned for 450 rwhp/440 rwtq @ 16 psi. The ACT set up was about 100.00 cheaper than the RPS/HPF combo from HPF.
Sean
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Sean
I am tending to shy away from RPS and HPF because on Supraforums I just read about serious problems like crankwalk and discs fusing for Mk3 owners.
X-man
member
Dec 5, 2005
309
Pulaski,Va
I gaurantee that there is some serious stress on the thrust bearing with the RPS PP. This is why I discontinue the use of clutch switch for starting, so there is no dry start up on the thrust bearing with excessive pressure against it.
