Precision 62mm Billet Turbo 6262
V band in and out is just more money out of your pocket.
Qsv
Non divivded mani
Divided turbo housing.
Qsv closes 1 side of the divivded turbo and let's all 6 cylinders pump air onto the turbine wheel. Creates faster spool but will choke off in the top end that's why the valve opens after a set psi and let's the turbo work like normal. Get faster spool and better low end with no crazy lag and still have top end.
The 6265 would be better for a 7m or 2jz.
Bigger the housing more lag but higher top end revs. Bigger the turbo more lag. Divivded helps spool faster if the mani is divided and seperated by companion cylinders.
