Eric (bloodasp90) boiled his PS fluid in his Skyline while racing. Not good when traveling at 100+ MPH. Heat bad, cooling good
Poodles;1246238 said:Oh, another point is that Toyota put a better cooler on the 91+ models, seems that they knew it was an issue too...
jetjock;1294605 said:^ What I use too although any filter is better than nothing. The best one is a true hydraulic filter. And don't be putting it in the high pressure side. That would be bad...
Poodles;1246217 said:High RPM + using the system (turning) = power steering fade.
I've never lost it, but I have felt it fade considerably doing canyon runs...
sweetlikechutny;1295677 said:and where would i install the cooler? (high pressure, or low pressure) before or after the filter?
My car did not come with the power steering cooler.
