Try taking your window switchs apart and cleaning the contacts inside, that is usually the problem.
Stock alarm is activated when you hit the door lock switch or lock the doors with the key. Unless you've got the enhanced factory alarm, the alarm can only be set off by opening a door, hatch or hood without using the key. After the alarm is set off it disables the starter.
