You can drive an A70 just fine without power steering. Parallel parking it is another story, but I've done that, too. If it's bad enough to CRUSH the reservoir, then it's probably done other damage that's more likely to make it undriveable.
I'm not much of a bling person, I will take functionality, unless there's a performance reason to upgrade. The PS fluid reservoir isn't going to give me any performance, so the stock unit is fine. I WOULD however like to have a better mounting solution than the one that I used in my '89 for the last few years. (Using a piece of twisted wire to hang it from a T-clamp bolt on my upper IC piping. Total ghetto solution, though it worked...) So this time I intend to not do something "good enough for now" since experience has shown me that "for now" will extend until I run out of anything else that I might want to get done on any project with any of my far too numerous hobbies. I have a lot of projects with things that were good enough to get things working "for now" and have been left that way since. (Though I suppose this means that it really was good enough, since it lasted...)
