Power steering questions
black89targa
Banned - (I'm st2b!)
Jun 15, 2008
73
versailles
IJ.;1073141 said:
LHD Racks look very different Nathan, I'm NOT seeing any PPS there though!
(usually a small solenoid and wires)
Thanks IJ Im so glad to hear that no pps is there!
Rennat;1073145 said:
leave the power steering on. i just put mine back on after not having it for a year? maybe less... and i'll never put myself thru that again.
even though its on the lighter side, 86.5 sport model, with a bunch of crap gone and e-fans... i could turn the wheel pretty easy without p/s. but with p/s, good god its so easy! but i lost most of my 'road feel' that i had.
if you want to elimiinate the pump, get a spare fitting that goes onto the rack, and then run a feed line to the rack via the overflow, and then just cap the big nipple/old feed for the pump, i had it that way and had no problems. just need space for the fluid to go when you go from full lock to the middle.
Sounds good to me. ill have to get some diagrams and figure out how to get p/s working. Shouldnt take long cause the sticky says it's been covered bunch of times.
Once again thanks yall!
But looks like its back to the search button for me.
black89targa
Jun 15, 2008
73
versailles
Zumtizzle;1073163 said:
Ian, PPS > You.
Thats one upgrade you need. :)
I believe Ian is the stig from Top Gear....
But back on topic im gonna do a semi writeup with pics in this thread about how I get the ps to work when i get to it.
Thanks guys!
Ian, PPS > You.
I'll drive my Bud's car and decide from there ;)
(I have enough outputs on the MoTeC to make it work how I want)
Mine is pretty damn good with the front end geometry I use though.
black89targa
Jun 15, 2008
73
versailles
Zumtizzle;1073178 said:
^i'm confused?
You have a 1JZ, but a non pps car, and want to add it?
I want to delete my power steering. I wasnt sure if I could because I thought I had PPS. Now that I know I dont have PPS Im going to try to get my power steering working again, or cap it off somehow.
