annoyingrob;921756 said:Wrong.
The vacuum lines are an idle-up valve. When you turn the wheel, the PS pump has an increase in pressure in the HP line, which opens the vacuum valve (it's connected to the HP line). This allows vacuum to run from the intake manifold, to the intake piping just in front of the throttle, creating essentially a vacuum leak to raise idle slightly so the pump isn't bogging the motor down.
wut he said ^^
