So I am looking at revamping all the lines that could possibly leak on my aged PS system. Im trying to do all this before the weather takes a turn for the colder.
I already replaced a leaking right steering racks seal/boot with a rebuilt rack.
I am planning to purchase the Driftmotion PS Hi-Press line w/fittings.
I am trying to trace the path of the fluid and hose sizes that I need to purchase to seal and secure the system.
Correct me if I am wrong please,
- Starting at the PS Reservoir 3/4" ish rubber suction hose leading to PS suction nipple on PS pump.
- Then we have from the PS pump High pressure output line to steering rack.
- then we have line from steering rack to PS cooler.
- then we have line from cooler to return nipple on PS Reservior. Looks to be 3/8" ish diameter hose.
My question is, to replace all the low pressure rubber hose, what size hose diameter do I need and how many feet of each diameter? I can only see about a foot of 3/8" rubber line from hardline coming from behind pass headlight leading back to the reservoir and the larger 3/4" or 1" diameter line leading from reservoir to pump.
Are there any other soft rubber lines that may be in need of replacement on the PS system?
Sorry for the lengthy post but searching has gotten me vague topic and the TSRM steering chapter didnt quite have a picture of the entire PS fluid & cooling system route. (unless I looked in the wrong section)
Any info would be appreciated,
Thanks!
Thanks!
