Ok, so trying to tighten the tension on the power steering belt, I don't see any spot for a breaker bar to be fed into the housing...just sort of leveraged it as much as I could and got some tension in it but it's got about 1/2 inch of slack in the belt..I don't know what it had before so I don't know if this is good enough or it should be more...the manual says like 100lbs, I don't have a gauge.
So two questions, what is the proper way to get some tension on the belt? Is there a spot for a breaker bar I'm not seeing...or some adjustment bolt? Also how much tension should there be? How much play in the belt when it's at proper tension?
:1zhelp:
:1zhelp:
