Power gains from Meth/Water injection?
suprafanatic
1,607
Greenwood, IN
Im looking into geting a Meth/water injection kit and i was wondering what kind of power gains I would get from it? For those of you that have meth/water injection kits did you notice a power increase? and if you have dyno'd with it how much HP did you gain? thanks!
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
From what I understand, it doesn't directly give you any HP. What it does is allow you to run higher boost on pump gas. I don't have experience with it, but my buddy Bill (can't ever remember his screen name) runs it in his MKIV and swears by it.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
Benefits:
Lower IAT, run more boost, more timing, which makes more power. And it keeps your combustion chambers squeaky clean! the pistons too.
Cons:
gotta tune for it, needs a failsafe in case you run out and your racing, just another thing that could "fail" and cause you to blow your engine...
grimreaper
2,180
Dallas
^ yes. Im heavily considering it as well. Im digging around for how you tune with it in regards to af ratios so drop me a line if you have anything! stock ecu with piggy back, so only major advantage is more boost and bit more base timing....
wheres suprahero? what have you uncovered inregards to tuning with ice? errr meth :)
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Other than the tune adjustment required there is no downside to meth/water injection. Lowers temps and cleans your engine everytime it kicks in. You will see a HP increase in the fact that you can push a few more degrees of timing and its cooling agent, giving you a much lower incoming air temp and a much denser air charge. Its going once the new motor is done and all squared away
grimreaper
2,180
Dallas
so much tech info from these guys my head hurts. Makes it seem much more difficult.
http://www.waterinjection.info/
all things remaining the same, when WI is activated it will richen the wideband reading on the af ratio by replacing the fuel in the chamber with water/meth (or cramming it in there with the fuel). You can lean it back out to a desired af ratio and this seems to be where the detonation suppression comes from since waters cooling affect is drastically greater then fuel. Now with out adding timing (it can be if you have control of it), boost can be increased... simply for the fact that the temps are lower and the detonation threshold has been lowered, is this correct?
Am i on the right track? still a ways away for me getting the setup, but i want a good understanding of how to safely tune it.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
I wouldn't think think that running a standard 50/50 water meth mix would richen your tune all that much. An ideal tune is 12-12.5:1, most shoot for 11-11.5:1 just to be safe so I would think that you could tune for 12-12.5 and the WI would bring you back down around 11-11.5. This way even if the WI failed your tune would be somewhat safe. I cant speak from experience on this so someone please chime in if you know more. Now if you were tuning for straight meth that would be a different story.
I still haven't got to run mine yet. I installed my kit and the very next day I put it in the shop to be painted. I haven't even filled my reservoir up with my boost juice yet. I'm hoping to have my car back on wednesday and then I'll get it tuned thursday or friday. I will report back though...........scouts honor.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I've had a lot of experience with alcohol/meth injection. I ran it on by 7MGTE on two different turbo setups, and I ran it on my 2JZGE-T setup.
The amount of power you can gain (by proper fueling/timing/boost) is going to be dependent on the amount of meth you inject.
Please read the next information I provide with caution.
Cliffs at bottom.
Methanol injection adds more octane to the mixture, water/methanol.. same thing just less octane. Water injection will lower IAT's and prevent some detonation. I have had great luck with 100% methanol.
I was speaking with a member about two years ago, when I told him I was running methanol injection, he insisted that I was going to make less power because of it. He tells me that a VERY well known 7M member on this forum dynoed on his meth injection setup, and then dynoed without the methanol kit and instead ran racegas. He made more power per PSI on racegas. The difference was pretty supprising. I knew what I had in mind so I said 'whatever' and went along my way.
Let's jump forward a year.
I take my car to the dyno. I've done a lot of re-search and street tuning to my 2JZGE-T setup, and found what I feel is a very comfortable, conservative timing map, and all my air fuels are dead on. There was nothing about my engine that I felt was under par, so I knew that I would be putting down some decent numbers. Long story short I didn't.. I did 450whp at 26psi or something ridiculous like that..
Knowing that my setup was solid, I was baffled. I knew it had to be the tune. I was working with the Stinger EMS, so I took advantage of that and added in a couple degrees of timing to my already "perfect" timing map. Using det-cans I could tell that I didn't hear anything out of the usual, but the car pulled amazingly harder than before. I decided to run up to the dyno, having changed nothing but a couple degrees of timing.
The dyno operator could'nt believe I was back. He said "you change anything?" I said "yup, I added a couple degrees timing". We both laughed and he strapped the car down, didn't thinking we'd see any gains that day.
First dyno pull 20-21 psi was 615whp, 27.5 was 677whp.
CLIFFS: TUNING and TIMING are crucial. Of course your 7MGTE running on a PIGGYBACK and the stock ECU are going to net more HP on racegas, you need proper tuning. You really can't just tune the AFR's and call it a day with any DECENT ammount of methanol injection. It WILL kill your power.
About tuning- not all tuners are experienced with methnanol, I sure as well wasn't. I was willing to push it to find where my timing needed to be.. only because I built the car, so I knew everything was solid, and I was listening for detonation. Don't take it to a tuner who is inexperienced. If they don't have a feel for methanol, you don't want them pushing the limits on your car without the proper detonation detection (which a lot of tuners don't use).
The smaller the nozzle you use, the less important having timing control is, but also the less boost you can run. It's a trade off.
**Please note that the timing numbers I threw into my personal dyno story are NOT going to be safe on your car. Just because you're running methanol and your numbers are below what you think they should be, doesn't mean your car will react the same way. I was running double the suggested volume of methanol on a very calculated setup.**
I hope this helps, sorry for the long post. Don't PM me with methanol questions, post them and send me a link.
suprafanatic
1,607
Greenwood, IN
Thank you for that information. very helpful in understanding somethings about meth/water injection. Its crazy that you jumped up that much in power with less boost just from timing and tuning! Im still using an SAFC for tuning so i dont think i would get as high of gains, simply because i wouldnt have nearly as good of a tune. But im pretty curious in seeing how much i could gain with meth injection and alittle higher timing.
grimreaper
2,180
Dallas
great stuff hottscennessey, that helps put it into perspective how much it can hurt with out full control of the ecu for tuning. What % to af ratio where you running? you said it was a large amount, im guessing 20-30%?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
grimreaper;1237116 said:
great stuff hottscennessey, that helps out it into perspective how much it can hurt with out full control of the ecu for tuning. What % to af ratio where you running? you said it was a large amount, im guessing 20-30%?
Imagine adding two 880cc injectors at full blast, which come online at 16 PSI. This sounds like a lot until you realize that it takes roughly twice the methanol to do the work gasoline would.
The 880cc rating is taken at 100PSI, and I never checked line pressure to try and figure out the *actual* flow rate. Without that information it makes it difficult to say exactly what %. I can guess based on my fuel map that methanol takes up over 20% of my AFR.
