:biglaugh: How do I get into the interior light in the roof to change the bulbs? I can't see any screws, but I don't want to pull at it if it's not clips incase I break it?
:1zhelp:
:1zhelp:
IJ.;1204719 said:It's clips and yes it's quite terrifying to remove the first time!
When it's out you'll find it's corrosion between the ring connectors and the aluminium rivets that's the problem not blown globes as suspected.
I put a small bolt in the vice and use a punch to squash the rivets down tighter and no more hassles.
92nsx;1204746 said:Remember to install a 5 or more led bulb there. I tryed install LED in mine with only one LED it it and it was not bright at all.
IJ.;1204991 said:I would have done the rivets while I was in there
