Adjuster
Put a tri rotor 13B based Mazda Rotary with a GT4088 turbo on there.
Small engine, not much tourqe, but in a light car like that, who cares? It would be 500+hp possible, and the motor is about as big as a mini keg of beer.
Short of that, get a Busa motor, turbo charge it, and put that in your car
Say 350hp, and super light motor...
The SR20DET has been done to death, but it's a good motor, that's for sure.
I doubt you will fit a I6 engine into this car.
Now, if you really want to become a drag race terror, find a used/wrecked STI, and go apeshit coverting your cup O Java to a AWD sleeper with the little Subaru motor tucked up front.. You might have to modify the frame rails, and apron to make the engine sit forward of the front tires, but that will line up the transaxle just right, and you can use your existing rear suspension as long as the gear ratios are right for the front axle.
Can you imagine a light weight, AWD car with say 350hp?
It would be a blast at the track, and anywhere else for that matter.
