Possibly bad afr
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
after market
But I figured it out .. What i was looking at was the vaccum line so i just hooked it up to my intack manifold
Pictures coming soon
meekmeek
Augusta, GA
Sry I haven't posted in a while. I had a few bad run ins. But I'll get her done tmr. I've had the worst of luck with everything lately. I'll finally have time for the car. I'll keep you up to date.
meekmeek
Augusta, GA
Okay so I did one last check of the engine codes before I started work and here's what i had. 22, 31, 43, 52. so we went through and fixed what we could. now I'm only getting a 31 and my temp gauge on the inside still isn't working. There's a slight black smoke now. And when I come to a stop the car stalls and there's a slight miss but the car runs like a champ otherwise. Any suggestions?
Turbo Habanero
4,229
Tucson,AZ
Stalling is because your bov and other things like tps being slightly off small vacuum leaks put them all together boom theres your problem
black smoke = Rich condition (to much Fuel) can be caused by venting bov with a AFM but not likely unless yuo combine it with a decent vacuum leak
Turbo Habanero
4,229
Tucson,AZ
when cruising at steady speed 14.5-15.5 give or take alittle
at idle 14.5-15.5 but may vary my car goes from 15-17.5 at idle
100% throttle 11.5 you do not want to be over 12!!!
meekmeek
Augusta, GA
Okay. I replaced the vacuum lines whether they needed it or not and I when I was inspecting my bov I pulled the whole intake and the accordian hose was cracked near the top but enough to let air in. Any quick fix suggestions til my new one comes in? Also so you think that could be a possibility?
meekmeek
Augusta, GA
Okay. So it stopped bogging down and shutting off on me. it seems to running fine for now. No more smoke or anything but the check light is on. I'll reset it in the morning and see what's next on the agenda. Thank you. I appreciate all you've done to help me so far.
