thats cool man. i called local shop this morn and ordered the (825-10) tee for 20 or 30 something dollars. i can live with that.
i ordered an NA stud from toyota. will take weeks. needs to come from japan. No fast and furious "overnight parts from japan!" coming for my supra
and from Racer parts wholesale i ordered
Accusump Oil Accumulator - 3 Qt
Accusump Electric Valve Kit
Accusump Mounting Clamps
-10AN Mocal Remote Oil Thermostat
Mocal 16 Row, 235 Matrix Oil Cooler with -10AN Fittings
Aeroquip Socketless 90 Degree Elbow Fitting -10 x 12
Aeroquip Straight Socketless Fitting -10 x 2
-10 Aeroquip Socketless Hose, Black x 22ft/6.5m
got a few extra fittings so i can mix and match as I'm sure it wont all go in how i plan. I already have the permacool filter adaptor and remote single oil filter head. both have the 1/2npt to -10an things screwed into them so i didn't need any more of those either.
Shame to see the shiny braided lines go but i tend to prefernce function over form (although form is nice to). Make way for progress.
She still drives okay with current oil setup. Im just babying it extra careful like when its cold and then not giving it too harder a time when its hot also have it like 1L overfull as IJ suggested
The cst for the penrite semi syn 10w50 i have in the car lands somewhere in between castrol edge 0w40 and 10w60 funnily enough
When i get all these parts in ill fill it back up with castrol edge 0w-40 and see how i go
The pressures look like the ones that Jdub said i need with my clearances when hot. except for when its in the upper rev ranges where the cooler relief valve starts to leech a bit too much pressure so ill try not to take it up to that for my 7m's sake
Does that all sound okay with u more experienced peeps?
