jzamerican;1890142 said:i cant wait till mine come in!!!! thanks ronnie!
OdysseusOnWheels;1891785 said:Looking forward to it!
Orion ZyGarian;1891708 said:I am definitely interested in a set of the steering ones at least, for now. I never heard back from your email.
Brewhaha;1893106 said:Hey Ronnie, another quick question. The little top-hats on top of the front subframe sleeves that go against the frame rail... Do I put those back in or leave them out when I re-install. I've seen people say both and wanted your opinion. Do they make a difference at all or are they just a buffer so the sleeve does mess up the frame, vibration dampening maybe?
OdysseusOnWheels;1893110 said:I'd like to know this as well.
ronniek;1893175 said:Throw away the top hats for the rear subframe bushings,you dont need to reuse them.
But you will need to reuse the top hats for the front subframe bushings.
Dont forget to lube the inside of poly bushings.
Cheers,
Ronnie
adampecush;1893301 said:Whoa, that's good to know.
Brewhaha;1893323 said:... Now I just need to figure out what is the best lube to buy for all these trinkets.
3p141592654;1893324 said:
