well i just finished my hg repair and i drove it for a bit and it almost overheated :cry:
i put in a new headgasket, water pump, lower rad hose, and a new rad cap.
no leaks or anything, but i might have not gotten ALL of the air out of the system. i just put my car in jackstands and with the jack under there too (might be a dumb idea) to burp the system. so when i was burping the system all it was doing was overflowing from the radiator top. i couldnt see any bubbles because only fluid was coming out. so after letting it do this for 5 min i took it out and drove it. it ran fine, but after about 6-7 min of driving the temp started going up. i stopped for a bit and then drove it and after about 4 min it almost went up to the reds.
should i let the car run without the rad cap until no more coolant spills out (and watch the temp gauge of course) or do you think it could be a shitty gauge hopefully?
im real desparate to get this thing running smooth. im going on 1 week and 5 days now. this is getting real tiring and i NEEED my car back.
