im in need of some help please
i got my map ecu today i installed it using crimps so i didnt what to cut the factory harness. the car Ran! both with and with out the map ecu plugged in. i went to the auto parts store and came back home and tried to start the car and it just cranks over... im not getting any spark at all and when the key is in the on/car off the check engine light is no turned on.
so i disconnected the entire map ecu and retraced my steps and all is good no broken wires and all fuses are good also when i try to start the car i hear a click comming from the glove box
other than that im completely confused on why this is happening
i tested coils and those are fine,i also noticed that fule pump dosnt prime with the key is on
could my ecu just be bad?
if i added power to the batt and ig sw in this pinout http://www.turboninjas.com/gallery/J...89ecu.gif.html
do you think that the car would get spark?
thanks in advance
thanks in advance
