*please help MKIII gods!* tried searching.. code 51 with no start. random....
SupraBo
Va Beach
kotu100;1838361 said:
Was just about to suggest to check your timing but then i saw u did and it fixed. hows the car running now? Did you check the ignition timing?
with the crank @ 0* piston 1 @ TDC, the 2 marks on your cam gears should match up with the marks on the rear gear cover.
this was done
Jumper Te1 and E1 in the diag box and start the car. Using a timing gun check the timing and it should be 10*.
10 degrees while running at idle? how should i adjust if not right?
Turbo Habanero
4,229
Tucson,AZ
Make sure it is at 10* at idle while in the diag box ports te1 and e1 are jumped with a paper clip these are the same ports you jump to check engine codes.
Now if the timing is off simply loosen the 12mm bolt that holds the CPS in place. Slightly turn the CPS back or forward until desired timing is reached, then tighten the 12mm bolt back down and take a second look and make sure the timing is where you want it to be.
