Please help choose a MHG!!
empera
Authorized Vendor
Philly.
Ok my primary choices are Cometic 1.31mm and HKS 1.2mm, i originally planned on going with Cometic because i've heard they're more forgiving to not too perfect blocks. Then i heard they SUCK....im not plannin to push that much boost (psi) 15-20 at most. What do you guys suggest? I've also heard that titan motorsports mhg are the same as the cometic, but they're 1.4mm? wats the deal with that?
please help!
THANKS.
Idealsupra
Orlando
www.tampabaysupras.com
titan motorsports = hks/greddy
and i dont know who told you the cometic suck...but i would swear by them...my own cometic has withstood a few overheatings from hoses blowing, and my timing being about 40 degrees advanced and pinging the shit outta my engine under boost and it held up perfectly.
my vote? cometic all the way....
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
We've had some problems with cometic gaskets here. I'm sure they would be easily fixable, if you know what to look for. One of the rivets was on a sealing surface... was crushed by the head torque, but we never got a decent seal on it from this.
To fix it, I'd just drill out the offending rivet before mounting it.
Empera, are you only looking for 15-20 psi on a stock turbo? That doesn't sound like MHG territory to me. Are you hoping to go higher eventually?
shaeff
Kurt is FTMFW x2!!!!
10
Around
i bought a cometic. i'll take my chances. :)
-shaeff
Idealsupra
Orlando
15-20 psi on stock turbo is stupid anyways hot air city...
as for the rivet issue...yes this is a common complaint because cometic had made a batch that were messed up...but they got shipped anyways....mine didnt have that problem so i got lucky...but like you said grim if you get one with a rivet either send it back and get another one OR drill out the rivet...
empera
Authorized Vendor
Philly.
how much psi is best for the ct26 on MHG and bpu's? wat would be best for 15-20psi? i was doin 10 or 11...
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
From what I've heard, 15 psi is the upper limit on a stock snail, and even at that the life expectancy more than likely isn't there.
This is also very dependant on what you consider to be BPU mods.
GJ: My TMS had a rivet in the wrong place as well!
empera
Authorized Vendor
Philly.
looks like im gonna be goin with cometic, from 935motorsports. i hope i wont be disappointed.
Got the block pretty clean and smooth, some things are kinda engraved but nothing too serious. Gasket Scrapper did the trick.
empera
Authorized Vendor
Philly.
basic performance upgrades...
such as exhaust, ic pipes, ic, intake, etc, etc...The basic stuff..
88turboma71
el3men2
nyc
How long ago were these batch of bad cometic head gaskets made? in my previous motor i had a hks, but know i am going with the cometic. with the hks i leaked oil. from the head and block mating area.
shaeff
10
Around
GrimJack said:
Hey Shaeff, can you post a photo of your Cometic? Or is it already in the car? I'd like to post a pic of what to look out for just for future reference with regards to this rivet.
i ordered it from AAP motorsports, along ARP studs. as soon as it shows up, i'll be glad to post pics of it. it should be here relatively soon...
-shaeff
IHI-RHC7
"The Boss"
Oregon
Anyone know of a 1.4mm headgasket? I need this thickness to obtain perfect quinch clearance on the new motor...
Pistons are poking .020" over the bores, so I want ~.055" to get .035" piston to head clearance. and I'm pretty sure the closest thing to .055" is 1.4mm
empera
Authorized Vendor
Philly.
where is the Best place and price to order a cometic mhg?? they seem tuff to find but havent been hearing good things from 935...
