Please God help...(Pilot Bearing Will NOT Come out)
Forgot to mention that it probably wouldn't be a good idea to use heat. Oil seal right there, crank is forged, ect...
Grinder works but it's time consuming as all hell, is the engine in the car still?
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
Couldn't you Mig weld a bolt to the race making sure to keep the heat in check?
Yes, I have heard all the horror stories of welding bearings to journals, blowing electronics etc etc but if done correctly instances as described won't happen.
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
I figured heat would be bad because of the bearing just behind it, close tolerances and all. The engine is in the car, so tonight, I guess I begin the long process of grinding.
arz
Arizona Performance
Nov 14, 2005
955
Mesa, AZ
www.ArizonaPerformance.com
Get some safety glasses and a fan and your Dremel and you will be done in less than 5 minutes. It will take you longer to get in position than it will to get the race out.
Check out this link http://www.mytoolstore.com/dremel/mototols.html#100n10
Notice those 2 thin grinding wheels in the center of the accessories, and that little arbor on left not attached, I know Walmart and Sears both have those Dremel kits in stock and they have that exact, part for less than 20 bucks. Hell borrow sombodys Dremel and give it back with the accessory kit.
Seriously you will be done in less than 5 minutes. Once you get 90% thru, give it a whack with a hammer or pry it sideways with a big screw driver it will come right out.
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
VICTORY!!! I "borrowed" some military grade Dremel grinding discs from work and it worked. This is what was left. Thanks for all your suggestions.
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
I think that was the original bearing from 1987. I bought the car from a little old lady who bought it new and I don't think she ever had the clutch changed.
arz
Arizona Performance
Nov 14, 2005
955
Mesa, AZ
EXCELLENT!!! Was I right about getting into position taking longer than the actual grinding?
Glad you were successful without a torch or welding. I usually have no problems going the high risk route like that, but I have done it dozens of times and there are just too many things that can go wrong if your doing it for the first time.
s000pra89T
SuFra TurVo
Apr 18, 2005
620
VA Beach
Got your text yesterday....congrats. Nice Arz! *golf clap* :bigthumb:
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
The grinding took a little bit because the first disc I used was a little too big. Once I got almost all the way through it, I chiseled for a few minutes and got nowhere. So, I made a second cut about a centimeter away and chiseled the piece between the cuts, then, it came right out. But over all, a short amount of time.
IJ.;1112361 said:
He's already removed the Inner and balls so the only thing I can think of is a dremel and a slitting disc.
Carefully cut through the outer race as deep as possible in 2 places then insert a small scredriver into the cut slot and hit with a hammer.
(while wearing eye protection of course)
arz
Arizona Performance
Nov 14, 2005
955
Mesa, AZ
I have never had to cut in 2 places. Usually I cut it so deep that the material is compromised and whatever ring there is collapses enough to come right out. Then again I never cut normal (perpendicular) to the bearing axis, I usually make an angled cut.
But it was IJ that made the suggestion first.
Glad it went well.
I tend NOT to cut right through (don't like risking marking the id of the part I'm trying to save) so it needs the 2nd cut to allow it to fail ;)
Never had to do this on a pilot bearing but haved done it on other jobs.
