If you want to go 2jzgte -
You can get an Aristo engine set locally or shipped
(whatever is easier for you). You will have to pay extra for shipping ($300 - 700)
A engine set will get you the complete engine with an auto tranny /harness/ignitor/ etc = Approx. $2000 ( + shipping if any )
1JZ bell housing = $300-$350
Mounts - approximately $250 -(check price)
1JZ Harness and ECU from a jza70 - at least $500 -$600 (IF You are lucky enough to find the harness.)
I would suggest locating Dr.Tweak on Supraforums.com and send him your Aristo harness so he can make it plug and play with your MKIII - Definitley will be less headache and cost less than the 1JZ harness/ecu setup.
You will need a custom Power steering high pressure line for the MKIII setup. ( $30 -100 ?)
Custom downpipe -
New clutch if your 7m one is not in good condition ( change the disc at least )
New IC and piping. ( 200 - 400 )
These are just some rough amounts...it can be higher or lower...
Custom downpipe -
