Place to drill for boost vac.
Fastway135
149
Mass
I mean a place to drill into my firewall so i can get the vac line inside my car.
supraman2251 said:
dont drill, use the nipple for the stock bpv
EDIT: or do the T thing...
I'm running an hks ssqv
Very welcome!
There's LOTS of crap on the other side of the firewall to run into with a drill that could be bad/expensive! ;)
A "trick" I use is a piece of coat hanger wire straightened out slip that in past the grommet then tape the Boost Line to it and pull it through.
SoupedUpSupra
The guy.
Sonoma County, Norcal
below the clutch master cylinder there is plenty of room
just double check on both sides and you will be fine! and it's much better than going thru the speedo grommet, which is a hassle cause speedo cables seem to break really easy on these cars (especially if you like doing e-brake pulls at 40MPH)
Will: Ignore that it's RHD but this is how I did mine you can see it coming out of the wiring harness.
bl
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
bl
IJ, remember, I'm no joe supra mechanic,
comming out of the firewall is a clear vacumm line right ? and you just tap into another vacumm line right ?...
I'm trying to see what your showing me in the pic ?
Will
