I think im in deep crap now...during the rebuild my buddy cleaned off all the permanent marker labels on the pistons with brake cleaner now i only can tell Pistons 1,2,4. Is there a way to tell the configuration of 3,5,and 6. Please help!
gaboonviper85;1355527 said:1. Never clean parts without being organized before cleaning
2. Never work with a friend unless yall have a system discussed before hand
3. Clean one thing at a time and put it down back in order in which it is to be installed
4. Scribe the order # in the bottom of piston in the meaty area around wrist pin
5. You are not fucked...take the block and pistons back to the machine shop and he can od mic the pistons and id "bore" mic the cylinders and relable the last 3 pistons.
DO NOT MIX UP PISTON RINGS!!!! that is the most important part...more important that mixing pistons as they are generally within .001 and will all work ok even switched but it's the rings that mean business
CyFi6;1355555 said:if they are all stock size, and you have the old bearings matched to each rod still, you can see what bearing number you have, and look at the marks on the crank to figure out which rod went where
gaboonviper85;1355574 said:So I take it you havnt gap'd the rings yet? If so you need to gap them..don't just put them in! Bring the block and pistons to the shop and the machinist can determine where they go...then he can double check with the plastiguage to make sure the bearings are correct.
Like I said..you're not fucked...you are seriously inconvienced and don't let your friend near your shit as either he was drunk or didn't have the sense to keep shit in order! If these bearings are clevites then it won't matter as all the rod bearings should measure the same as they aren't select fit like stock Toyota.
supersupramk3;1355585 said:Basically I gapped them and put pistons 1,2,4 in then thats when I noticed the issue of all the marked pistons gone. I am reusing the old rod bearings and am pretty sure they are the stock toyota.
suprahero;1355597 said::3d_frown:........This is part of the reason the 7m has a bad rep.
