Pick my new logo!
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
Speaking from a Vinyl background , The top Right looks the best and would cut easy out of vinyl. The Left 2,3,5 are cool but the hollow letters are a pain to make out of vinyl. (Like the SM logo, its a PAIN!) Vinyl guys would charge less for the top right. Plus I do like that one the best.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Back center, on the window.
That one
dugums
Better, Faster, Stronger
Apr 10, 2007
699
Chicago, IL
3rd down left column... I agree that the logo isn't that intuitive to read though. I would suggest carrying the "d" through a little (will make it appear like a lower case "d" rather than a backwards uppercase "d").
EDIT:
This is what I was thinking, but you would need to spend some time on it to make it look as good as possible:
You could also clarify the letters using highlight lines to put emphasis on each individual letter, here, the d is highlighted by black on the right side of the letter structure, the m is highlighted by red. You could just use different grey tones if you are trying to stick with a two color format.
Top right or bottom left.
If I could change anything, it would be to make them lean to the right like on a slant. ////// Like that but more of an angle.
Yblegal91t
it finally runs!
Apr 22, 2006
331
C1 outer
Being a graphic designer, i picked second one on left. Its the most conveying. stay away from tiger scratch type unless it works with teh company. def does not look like an import shop or car company. thanks
