Update: I replaced the cam seals, however, during removal, my friend took the caps off on the exhaust cam, which caused it to move. We put everything back together, and started her up. she sounds like shit, and doesnt react like she should when i play with the throttle. I checked as per TSRM with TDC and all that. When the intake cam is at TDC the notch marks on the cams arent at 12 o'clock. So im at this dilemma. Do I remove the timing belt, set the crank to the 0* mark and then adjust the cams to TDC and then put the belt back on? I'm somewhat lost here.
I bought a timing light and set it, but the notch on the crank pulley jumps from 10* to 0*.
Help please.
-Justin
Help please.
-Justin
