performance spark plug (need advice)
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Gap them when they come out of the box, as you should with most plugs (IIRC there are some that you shouldn't gap). Mine are at .28, seems to be a good area for a BPU 1jz.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
yeah coppers are ones you gap ;) ive seen people replace them every oil change or every other oil change something like that
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
if i decide to run irridum plugs which plugs should i run besides the ones that come in the 2jz's, are there anyother options? is there a such thing as a cold irridum plug? i know irridums burn really hot so i wasn't sure
tlo86
Jul 24, 2005
3,914
Colorado
lower heat range you mean?
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
stock - bpu > IK22
higher boost > IK24
i personally have bad experience with iridiums, the electrode broke off from 3 plugs and damaged head, valves and pistons
i've also seen another engine having this same problem
the electrode on a copper plug is much stronger, they perform better up to redline and they're much, much cheaper
why iridiums?!?
