Okay.. First... where the engine is at (some of you will know this)
Rebuilt 7MGTE Shortblock with Wiseco Pistons, polished rods and crank
Rebuilt Head (no porting, stock cams)
1.2 Cometic MLS Headgasket with ARP Studs
1000 cc ID Injectors
HKS EVC-S Boost Controller
HKS Fcon Vpro 3.3 Stand alone mated to a 90 M/T ECU (for idle control and A/C function)
3" vband DP mated to a HKS 3" catback (twin-tip muffler, cats removed)
Tial 44 mm Wastegate (dumptube vents to atmosphere)
HKS SSQL BOV
DM 7MGTE Intercooler upgrade
Supra MKIV Denso Fuel pump upgrade
Aeromotive AFPR
EGR blocked off
SP6262 Turbo DBB 0.68 ar
Still on wasted spark and stock ignition coils and plugs. Keeping my A/C and not planning on going with a FFIM. The R154 is a stage 3 build to handly up to 700 HP (I believe that is at the flywheel, but may be to the wheels) and am currently running a Spec 2+ pressure plate with the stock clutch disc (no slip so far). Stock flywheel.
Here is a dyno of where the car is tuned and set up for now:
So.. the question...
Do I have to pay attention to or plan to upgrade anything to go higher power with maximum reliability?
I am currently on the stock wasted spark setup (not sequential and not COP) so there are limitations, but I am not clear on exactly where the safety limits are.
I am going to run ultra conservative (safe) this summer and then go in for another tune next summer and at that point I would like to creep the power up. Currently I am running at 12 psi, but want to run closer to 16-19 psi. However, by discussions with Reg Reimer and my mechanics I am told that going higher is where my setup will start to run into the grey area with spark/timing and could end up roasting the motor if anything goes awry.
Note that I am not running on a track, this car is more for cruise/show than anything else at this time. If I free up a lot of funds I may start going more toward a track setup but for now I have a rock solid power plant.
Any thoughts to help me plan my next engine stage?
HKS SSQL BOV
Aeromotive AFPR
EGR blocked off
