People with aftermarket headers...
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
Sure, every little bit helps. Here's a pic of my NA, I have other pics of the motor, but they're on my other comp.
Mo
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
GotToyota? said:
Yeah, seems like the actual engine is the problem, but I'm going to the get y-pipe modified to 2.5" so I can benefit from the full 2.5" system. Also, should I get a test pipe and eliminate my cat?
-Matt
of course. especially if you dont have to go through emissions tests. if you do, you could always get a high flow cat, gut the current cat or take a test pipe, cut the cat in half lengthwise and weld half of it to the test pipe to make it look like youre running one. this is all if your state isnt too strict on emissions though.
only legal way i know to go is just get a high flow cat.
s383mmber1
3,614
Somers New York
Mo - Your cars sooo fuggin sexy.
Matt - A test pipe will give you great benifits, but will make it signifigantly louder and raspier. And smell not so pleasent!
But power is a gain for the test pipe!
Start looking to cams!
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
Mo87NA said:
I've got them on my '87 NA. Before I knew much about Supras I spent a lot of money on it.
Pacesetter headers,
High-Flow Cat,
Blitz Nur Spec Exhaust,
Modified AFM,
Civic Polished Intake,
1 Piece Aluminum Driveshaft
Magnecor Wires, etc
She goes pretty good. I can def. tell the difference between a "stock" NA and mine, but there's no comparison to boost. If I knew then, what I know now I could have done a lot more to my '91 Turbo. You live and learn I guess...
Mo
How did you modify your AFM?
-Matt
Will: Are there even N/A cam alternatives?
Clip
Oct 16, 2005
2,738
9
Virginia
gottoyota, im wondering about the afm and the cams too. answers, man, we need answers!
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
GotToyota? said:
Well I know it's actually supposed to be "headers", because "header" is for a 4 cylinder. BTW, there are gains when you get an aftermarket header, it's about 20ish at the most.
-Matt
I cant believe you just said this :nono:
and...
manifold = turbo, header = na
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
thorley/trd FTW!!!!!!!!!!!!!!!!!
Mo87NA
8
Upstate NY
I did it using an Old Sogi Mod. What it basically does is losen up the flapper on the AFM to allow more air into the intake. I dont remember being that hard, but I actually dont remember how to do it either lol. Do a search somewhere, you should be able to find it.
Mo
Clip
Oct 16, 2005
2,738
9
Virginia
ive heard about this one, something about bending a spring (if thats the one). if i remember right, its either really easy to mess up, or doesnt offer much of a gain. actually, this might have been another one; hell, i cant remember.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
if i had a few grand to blow on my na keeping it na(instead of spending money on college) ide go with some 10.5:1 or 11:1 comp pistons, 264 or 272 cams, safcII, WBO2, 3in exhaust and the modified pace setters, ARP bolts, MHG, and some mild porting. i think that it would have a little more pep this way :evil2:
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
That'd be cool. But I'm wondering what cams you could use, or where you could even find the ones you mentioned.
-Matt
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
s383mmber1 said:
Matt, start researching cams.
Itll be worth it. Have you looked into 1 peice driveshafts, lightweight flywheels and such?
I'm already looking into a 1 piece driveshaft. And a lightened flywheel is something I've been considering as well.
Here is an interesting guide I've found regarding 7M-GE cams:
http://users.tpg.com.au/users/loats/technical/7mge/camshafts.html
Apparently, TRD did make GE cams, but I'm sure they're a fortune. Would I be able to use aftermarket GTE cams? And what kind of gains are there from upgrading your cams?
-Matt
Mo87NA
8
Upstate NY
I may be selling mine in the future to fund the rest of my project. I'll let you know if I do.
Mo
